What octane of gas are you using with gas proces sky high these days?
![Big Grin](https://www.jaguarforums.com/forum/images/smilies/biggrin.gif)
I tend to fill up with Super unleaded since the car seems to run slightly better. At current exchange rates this is currently $2.24 a litre - or $8.48 for 1 US gallon. Standard unleaded is slightly cheaper.
It's $3.75-$4.00 a gallon for 91 in San Diego. They don't allow 93 or 95 octane at regular gas stations in CA. You can get 100 octane unleaded racing gas at specialty stations but it's $8.00+ a gallon.
Received 2,263 Likes
Most of them are just snake oil. Those that do work cost more per tankful to boost octane than just buying high octane gas in the first place. The labels on the bottle are very clever by stating how many 'points' the product will increase octane. By 'points', they mean 0.1 not 1.0.
Save your money.
Save your money.
tcarby (03-04-2011)
Ahh learn something new every day, did some reading on on it and found that it is usually Toluene/ Xylene that is in these boosters. Now that stuff is pretty damn cheap by the gallon, but what happens when you ' homemake' some of this with the classic toluene, mineral spirit, atf fluid mix and put enough in the tank to raise the octane a few integers? Is it going to slowly eat the engine alive?
I use the 91. Somebody wasn't happy with the old system and so they came up with a new one which changed the numbers.![Icon Shrug](https://www.jaguarforums.com/forum/images/smilies/icon_shrug.gif)
Watch octane boosters. Some contain lead and say bye-bye O2 sensor.![Icon Doh](https://www.jaguarforums.com/forum/images/smilies/icon_doh.gif)
If you have a later model car, it will have "knock sensors." When the low octane gas pings, the ECM changes the spark advance and cam timing. You may think that you have 11 to 1 compression ratio, but delay the closing of the intake valve and it is the same as having 7 to 1. Watch what you do with supercharged engines.
FS[Western US]: XJS Lock Set with Keys- Doors, trunk, glove, gas, and ignition
XJsc-guy
11-23-2015 01:56 PM
rsa760041
23
09-25-2015 01:33 PM
MC36
US Lower Atlantic
09-01-2015 07:34 PM
