wheels compatible to xj6
Received 9,009 Likes
Guest
Posts: n/a
Hi, lots of Jag wheels will fit. 3 things to look at - PCD, offset, and centre bore
here is an example of what will fit:
Model P.C.D. ET C.B.
Jaguar XJS 5 x 120.65 18...20 74.1
Jaguar XJ6 5 x 120.65 18...20 74.1
Jaguar XJ12 5 x 120.65 18...20 74.1
Jaguar XK8 5 x 120.65 18...20 74.1
the PCD is common, the offset and centre bore can be odd - though the centre bore is normally easily turned out if you find wheels off another make. XJS wheels are a really common swap on you model (here anyway)
good luck
good luck
Last edited by beand; 06-19-2009 at 06:41 AM. Reason: computer crashed before finished!!!
rusty37
04-05-2020 07:40 PM
Chet Ramnarain (bozzner)
09-03-2015 12:21 PM
