where does speedo get it's signal from
Received 13,425 Likes
And yes, the vehicle speed signal is critical to orchestrating proper gearshifts between the ECM and TCM, so if you have no speedo you will likely also have transmission issues.
93SB (05-17-2020)
Hi Steve, Just today I got done with replacing the rear end in my Moneyfunnel. All went well, except that at first I had an ABS light and speedo only over 40 MPH. The culprit was the left wheel speed sensor not being installed all the way into is spot. A couple of taps and bolt tightened and all is good.
