XJ40 ( XJ81 ) 1986 - 1994
will a 91 xj6 sovereign front subframe interchange with a 94
Old 04-17-2012, 01:35 AM
strange30's Avatar
Default will a 91 xj6 sovereign front subframe interchange with a 94
i have a 91 xj6 that needs a front subframe. i found a perfect one from a 94 anyone know for sure if they will interchange?
Old 04-17-2012, 02:53 AM
mrtalkradio's Avatar
Welcome to the forum, you should go introduce yourself in the new member area. After about 10 posts you will be able to use the search function on the forum as well.
The answer to your question is yes.
strange30 (04-18-2012)
Old 04-17-2012, 08:47 AM
Im fairly certain that if you're changing the whole thing it will work fine. Just curious what's wrong with your subframe?
Old 04-17-2012, 04:21 PM
strange30's Avatar
driversside upper a arm mount rusted out
Old 04-17-2012, 04:22 PM
strange30's Avatar
thanks everybody very much
rusty37
04-05-2020 07:40 PM
carcycle
09-07-2015 04:14 AM
Harry Dredge
09-05-2015 02:44 AM
Jag-o-nomic
09-04-2015 03:07 AM
Chet Ramnarain (bozzner)
09-03-2015 12:21 PM
Quick Reply: will a 91 xj6 sovereign front subframe interchange with a 94
