Windows stuck closed
SO I couldn't find this issue posted in the xj40 threads anywhere.. Pretty standard issue, back two windows won't go down, though when I hit the switch they do make a 'click' sound but don't move or anything.
How do I go about this? Summer is approaching and I am hella not suffering without windows.
thanks Bob, I did try the key trick but nothing happened with any of the windows.. does my model have that feature? What are the steps exactly? Drivers switch pack is not set to lock.
Global Open/Global Close is operated by inserting the key into the driver's door outside lock and turning/holding the key in the lock or unlock position.
Holding in the LOCK position should close all windows and (if equipped) sliding roof.
Holding in the UNLOCK position should OPEN all windows.
It comes in handy when the ambient (and inside car temp) is really hot and you want to vent the interior before entering.
It also is convenient when it starts to rain and you just want to close the car up in a hurry.
bob
bob
Don B (08-08-2017)
