Windshield washer fluid leak
I have accessed the reservoir bottle, and now I need help. There is an electrical part that pushes down into a rubber grommet in the bottle and it leaks when I put water into the lower half of the bottle. There is also another electrical part disconnected that appears to connect to the headlight washers. The hose leading to the windsheild is also disconnected. Obviously all of these disconnections are surely going to leak, but it is clearly leaking from around the electrical part that pushes down into the bottle.
I'm not sure how everything should connect. Does anyone know where I can get a diagram or a manual showing how the system connects?
aholbro1
08-05-2021 05:02 AM
Richard_gib
09-12-2015 07:08 PM
