XJ40 ( XJ81 ) 1986 - 1994
Wiper Park problem
Old 09-18-2015, 12:59 AM
British Ride's Avatar
Default Wiper Park problem
Greetings. I wanted to share the solution I found today for a non working wiper park problem. Symptom: Wiper blade stops at various points. There are two power sources for the wiper. One for run and the other to park the blade after turning off or during intermittent operation. Under the front passenger trim piece under the dash there are a series of relays and modules. One of these is the wiper logic module. Near this on the LH side is a cable that has a 5A fuse connected to it. In mine the fuse was open. This prevented power from being applied to park the blade. I checked the park switch first by opening the wiper motor transmission. It was operating correctly. There are 4 or 5 screws holding the panel in place. Fully remove all of them or you will have trouble replacing the panel-ask me how I know. Hope this helps.
Old 09-18-2015, 01:57 AM
manwich66's Avatar
Yup.First thing I looked up.First thing to fix.
Welcome from Jim and Cin,Only a few more to go..fixxes that is...
Lots of help here,put your car specs in your sig,it helps when all the brains collect.
Welcome,Jim and Cin.
SteveSheldon
UK & Eire
505
07-14-2016 04:48 AM
Thang Nguyen
10-12-2015 01:25 AM
mcdutch
09-04-2015 03:38 AM
XJsc-guy
09-02-2015 11:43 AM
MC36
US Lower Atlantic
09-01-2015 07:34 PM
Quick Reply: Wiper Park problem
