Xj 40 6.0 V12
Xj 40 6.0 V12
Would like to have some advise.
Went to look for a Xj40 (1993) V12 6.0.
Car looked fine except for a oil leak in the front, most likely the stearing.
Is this a common problem for this type and is it a expensive fix?
Also there was moist in the boot originating on the leftside tankfiller. Could it be a clogged up waterdrain under the filler cap?
Thanks,
Thanks,
Hi
Others more knowledgeable than me will be able to advise on the power steering leak. Being an xj12 owner for just a couple of months I'm still on the steep part of the learning curve.
As to the boot leak that sounds about right. An xj40 I recently looked at just before I bought my xj12 had the same problem. It had been parked in the rain and the rubber surround under the filler cap was full of water.
Steve
Steve
Bleujag (10-26-2014)
FS[Western US]: XJS V12 Convertible
marklcap
09-29-2015 12:41 PM
