XJ 40 heater vacuum lines diagram
Does this help?
Vacuum System
The vacuum supply to four solenoids in the system is from the engine manifold via a reservoir located under the battery and a non return valve.
The vacuum solenoids are located on brackets beneath the heater assembly.
Components operated by the solenoids are:
1 Defrost/Demist flaps which are held closed by vacuum identified by a green vacuum supply tube.
2 Recirculation/fresh air flaps which are held closed by vacuum indentified by a blue vacuum tube.
3 Centre vent, which is opened by vacuum identified by a black vacuum tube.
4 Coolant valve which is closed by vacuum identified by a red vacuum supply tube.
Source JTIS XJ6 Service Manual Vol 4 (note to Mods are you OK with this citation?)
Good luck,
Vacuum System
Good luck,
Does this help?
Vacuum System
Good luck,
Vacuum System
Good luck,
So, if some out there knows the answer, I would much appreciated.
Ah can't help you there, I thought the thing was already in bits.
However: I think I get the gist of your problem. The car is almost in bits and you have located the vac solenoids all neatly randomly connected with assorted inlet and outlet pipes but you don't know what goes where further down the line?
Here's where I'll get slammed.
To identify the outlet pipe and its corresponding component ONE at a time disconnect an outlet pipe from the solenoid and then give it a good suck. Whatever it activates should move and you will have identified it. Make notes.
To identify which solenoid does what. One at a time. Stick your finger over the end of the outlet connector on the solenoid and one by one operate the controls, when you get sucked in, as it were, you will have identified which solenoid corresponds to which control. Make notes.
You might need to power up, because I don’t know how much vac is held in the reservoir.
PS, If you have a good friend they might agree to help with the above.
Now reconnect accordingly.
I have not tried this personally on a Jag, and you do this at your own risk.
If anyone else has a better method, feel free.
Translator,
I have a quick question...The information provided for the heater vacuum lines are for a 1990 model. With the exception of the relays, will the same apply for a 1988 model?
Presently, the coolant valve on my vehicle is MIA due to the previous owner. I'm trying to determine if the vacuum line that went to this valve should either be left open or closed. I've tired both methods and there doesn't seem to be any change in how the climate controls work (with the exception of the windscreen vents which pushes air regardless of hot or cold selection on the climate control). I know the windscreen vents are controlled by a vacuum which is probably defunct due to the car's age. Perhaps I should put a small check valve on the vacuum line....something I can pick up for use on an aquarium fish tank for the air pump?
Thanks in advance.
Thanks in advance.
Sadly Fritter you have arrived a the limit of my knowledge, I simply don't know. I am just an amateur that "enjoys" all things mechanical and can follow procedure to get things moving again, or discover why they don't.
You need one of the Techs to pick up on this, which they probably will do given time. Just be patient and try to remember that they can't answer everyone immediately all the time.
JTO, Po, you hovering anywhere out there?
Hmm, while you are in there why not go that extra mile with the aquarium idea and replace the centre console. Look forward to the pics;-)
Sorry not to have been of more help.
Translator,
Thanks for the feedback. I will investigate the air check valve as an alternative perhaps this weekend. The vacuum line in question is colored orange and runs along the firewall, inside the engine compartment, right above the windscreen wiper motor. It has a rubber connector which was associated with connecting to the coolant valve (which is now just a straight pipe). As for pics...I have to review the FAQ one of these days for posting on this site.
Regarding the removal of the center console....no no no. The climate control is operating fine and I don't want to jinx it at this time. When that time does arrive, I will replace all the bulbs which are presently dim but not completely out.
This car so far runs like a champ considering its age and mileage (169,000). I've been replacing things as $$ and time allows. Just recently, I had the rear shock conversion installed. That made a BIG difference in the ride.
Can you believe that the original fuel pump is operational (I may need to change this at some point because it has that high pitch hum once in a while). Either the previous owner was good to the car or the right manufacturing conditions existed on the day it was built.
For anyone that needs this information, I found a vacuum diagram:
http://www.jag-lovers.com/books/xj-s/images/Image16.gif
http://www.jag-lovers.com/books/xj-s/images/Image17.gif
clubairth1
29
05-10-2024 12:57 PM
