the XJ40 Book
the XJ40 Book
The following is probably one of the first documents I found on the Internet before I came here. Richard Hyde put together a bunch of documents he found on the Jaguar mailing list, originally jag-lovers@sn.no.
The link to it is here: the XJ40 Book
I fear someday it will disappear, so I've assembled it into a .zip and uploaded it here. I don't think I am doing anything unscrupulous by doing so.
If you download it to your machine, unzip it and open the .html file with your browser, you can read it locally or without being connected to the Internet.
Here is the Index to all of the good stuff with which it touches base.
Jaguar XJ40
Tips and Tricks
From the Internet
Tips and Tricks
From the Internet
1. Index
2. Foreword
2.1 The Internet Bit
2.2 Other Stuff
2.3 The Author
3. The XJ402.2 Other Stuff
2.3 The Author
4. General Advice
4.1 Bodywork:
4.2 Electrical:
4.3 Drivetrain:
4.4 Summary
5. Bodywork etc4.2 Electrical:
4.3 Drivetrain:
4.4 Summary
5.1 Windows
5.2 Front Grill
5.3 Door Handles and Locks
5.4 Replacing Head Liner
6. Electrics5.2 Front Grill
6.1 Engine Warning (early)
6.2 Check Engine Light
6.3 Lamp Modules
6.4 Installing Front Fog Lamps
6.5 Radios
6.3 Lamp Modules
6.5 Radios
6.5.1 Adding a CD Player
6.5.2 The LCD display only showing partial characters
6.5.3 Channels would cutting out intermittently
6.6 Lights On Warning Buzzer
6.7 Factory Alarms
6.8 Reprogramming Factory K19 Alarm
6.9 Wiring Diagram
7. Wheels and Suspension and Brakes6.7 Factory Alarms
6.9 Wiring Diagram
7.1 Hydraulic System
7.1.1 Self-Leveling Suspension
7.1.2 Brake Switches
7.1.3 ‘Pulsing’
7.1.3 ‘Pulsing’
7.2 Anti Lock Brakes
7.3 Cleaning Out Anti-lock Braking System
7.4 Steering Racks
7.5 Differential Bearings
7.4 Steering Racks
7.5.1 Changing Bearings without removing Diff.
7.6 Changing the Differential Oil
7.7 Front Wheels and Stub Axles
7.8 Wheel Bearings
7.9 Drive Shaft
7.10 Sports Pack
8. Air Conditioning7.7 Front Wheels and Stub Axles
7.8 Wheel Bearings
7.9 Drive Shaft
7.10 Sports Pack
8.1 A General Overview from an XJ-S Viewpoint
8.3 Centre Vents
8.4 Vacuum Schematic Diagram
8.5 Recirculation Flap
9. Engine8.1.1 Air con blowers:
8.1.2 Temperature Sensors:
8.1.3 AC Computer:
8.1.4 Evaporator and drainage:
8.1.5 Electric Fan:
8.2 Temperature Sensor8.1.2 Temperature Sensors:
8.1.3 AC Computer:
8.1.5 Electric Fan:
8.3 Centre Vents
9.1 Oil System
9.2 Oil Pressure Gauges
9.3 Electric Cooling Fan
9.4 Adjusting Idle Speed
10. Fuel System9.2 Oil Pressure Gauges
10.1 Fuel Pump
10.2 Fuel Injectors
10.3 Fuel Non-Return Valve
10.4 Replacing Fuel Lines
10.5 Throttle Position Sensor
10.6 Purge Valve
11. Fault Codes10.2 Fuel Injectors
10.6 Purge Valve
11.1 Code 3
11.2 Code 18 Fuel Fail
11.3 Code 26
11.4 Code 44
11.5 Fuel code 89
12. Accessories and Other Info.11.2 Code 18 Fuel Fail
11.3 Code 26
11.4 Code 44
11.5 Fuel code 89
12.1 Windscreen Washers
12.2 Seat Belts
12.3 Trim and Paint Codes
13. Appendix A
12.2 Seat Belts
The following 2 users liked this post by Trick Freestones:
British Ride (09-24-2015),
Kay (07-12-2015)
FS[SouthEast]: Books - Various Jaguar Titles
SCMike
11-25-2015 07:55 AM
NTL1991
XJ40 ( XJ81 )
09-20-2015 06:22 PM
