XJ40 ( XJ81 ) 1986 - 1994
XJ40 died and no start anymore
Old 07-01-2021, 09:32 AM
Received 12,947 Likes on 6,469 Posts
Hi Carmelo,
The ignition coil is a known failure point. Your grounded distributor rotor button may have caused the coil to run hot, possibly accelerating its failure.
What is curious to me is that in your video I do not see the ignition amplifier module, Part 4 in this diagram:
Does your car have this module, normally mounted under or next to the ignition coil?
Cheers,
Don
The following 4 users liked this post by Don B:
93SB (07-09-2021), MountainMan (07-08-2021), xj40_197042 (07-01-2021), XJRay (07-09-2021)
Old 07-01-2021, 09:35 AM
xj40_197042's Avatar
Hey Don !
Yes I have the amplifier, but the coil have been moved upper by the previous owner's mechanic when the coil was changed, to avoid overheating. The coil has only 3000 Km ...
Can I test the coil to know if it's still good ?
Old 07-01-2021, 09:43 AM
Originally Posted by carmelo42
Hey Don !
The fact that you have spark suggests the coil and amplifier are still working, at least marginally. It's possible the spark is weak, though, if the coil is shorting internally, which that clicking sound could indicate.
The following 3 users liked this post by Don B:
93SB (07-09-2021), MountainMan (07-08-2021), XJRay (07-09-2021)
Old 07-04-2021, 05:49 AM
mickvic's Avatar
Yes I noticed the clicking Don...at the same time as the clicking I can see some movement in the small amount of liquid on top of the lead going to the top of the coil.
Old 07-04-2021, 07:49 AM
Exactly !
I have the clicking noise and the "bubbles" on the liquid are bouncing at the same rythm.
The liquid is LHM (green liquid used for rear suspenspion) leaking from unsued pump and pipe (hydraulic suspensions have been removed). I have ordered metal plate pu instead of hydraulic pump : there will be no leak next week.
I have "news" :
I'm now sure it is ignition related problem : I can reproduce in 2nd gear, 3rd or 4th : when the car is at operation temperature, and RPM above 2500 and stabilized speed : RPM needle is bouncing ...
Old 07-05-2021, 06:31 AM
Hey there
I may have found the initial problem with my ignition timing.
The crankshaft pulley is moving around the crankshaft ... All parts of the pulley are tighted together, so it's not the harmonic bumper.
I think it is the crankchaft key which is broken, allowing the pulley to turn, and the ignition point is not aligned anymore :
Don B (07-05-2021)
Old 07-05-2021, 08:42 AM
Hi Carmelo,
That is definitely a problem! How did you have any spark at all with the crank pulley not turning to provide a CPS signal? Is it possible the Woodruff key has broken just recently?
Cheers,
Don
  #28
Old 07-05-2021, 08:45 AM
Yes it is
The whole pulley is loose, but can not do an entire revolution. It can turn about 1/16 of an entire revolution : you can see in the video the maximum movement of the pulley while crankshaft is motionless.
So when the crankshaft is turning the pulley turns, and the CPS can provide info. But as the pulley is loose, the CPS cannot always provide a good information, I think this can explain my jerks at stabilized speed : what do you think ?
I have to take out the pulley to check if the key is shot.
Don B (07-05-2021)
Old 07-05-2021, 10:14 AM
I hope you find the Woodruff key has sheared but is catching on itself and not that the central sleeve of the harmonic damper has broken.
93SB (07-09-2021), MountainMan (07-22-2021), xj40_197042 (07-05-2021), XJRay (07-09-2021)
  #30
Old 07-05-2021, 10:17 AM
I'm waiting to receive the 1-5/16'' socket (here in France we have tools in mm not inches !) to remove the pulley ... I'm scary as hell :'(
  #31
Old 07-14-2021, 11:13 AM
So I received new woodruff key and 1-5/16’’ socket, and now the car is running great
Very lucky it did not damaged the cranckshaft or pulley !
The following 2 users liked this post by xj40_197042:
Don B (07-14-2021), Redlock (02-13-2022)
  #32
Old 07-14-2021, 11:22 AM
Congratulations, Carmelo!
Great detective work!!!
Cheers,
Don
The following 2 users liked this post by Don B:
MountainMan (07-22-2021), xj40_197042 (07-15-2021)
WattsXJ
XJ40 ( XJ81 )
08-14-2017 06:43 PM
mickleon
XJ40 ( XJ81 )
04-06-2012 12:37 PM
malibudav
XJ40 ( XJ81 )
03-02-2012 03:56 AM
Frankie
XJ40 ( XJ81 )
10-07-2009 08:33 AM
george
XJ40 ( XJ81 )
11-18-2008 03:34 PM
Quick Reply: XJ40 died and no start anymore
