XJ40 power antenna stopped working
Hi!
Could someone help me with my 1990 xj40 power antenna? It worked normally and then I just took off the radio when checking the speaker wires. When I put the radio back the power antenna did not pull up anymore.
Is there a fuse for antenna?
The radio is some old Philips cassette player and it has a sticker which says that blue wire is for power antenna. The blue wire is attached to light green / black wire which should be correct as the original wiring diagram says.
Should the light green / black wire get 12v when turning on the radio?
Received 13,203 Likes
Hi 1990XJ40,
The antenna Up/Down function is handled by the Central Microprocessor (CPU) in response to signals received from the radio head unit on a Light Green wire with Black tracer stripe. The CPU energizes either the Antenna Up Relay or Antenna Down Relay to power the antenna motor with the correct polarity to raise or lower the mast. You can download the wiring schematics at the link below. See pdf page 62.
Jaguar XJ40 Electrical Guide 1990
Cheers,
Don
Cheers,
Don
The following 3 users liked this post by Don B:
Thanks.
Im not that pro with that diagram, but is there fuses anywhere for antenna?
Hi 1990XJ40,
Cheers,
Don
Cheers,
Don
If you have the Driver's Handbook, it will also have fuse charts.
Cheers,
Don
The following 2 users liked this post by Don B:
93SB (09-10-2022),
MountainMan (09-05-2022)
Padrino
05-20-2013 08:48 PM
