XJ40 seats in a MKII
Guest
Posts: n/a
I have seen MKIIs with XJ40 front seats. Does anyone know if the rearseat top and bottom cushions fit in a MKII as well? My MKII (just purchased) has two locating pins for the lower cushion. Thanks for the help.
BT7
BT7
xj 40 seat coversion into mk2 jag
Hi i have recently completed this conversion on my mk2 the front will fit with a little alteration to the seat brackets.
The rear however will need to be taken to a reliable trimmer to strip the leather and then cut, shape and then reweld the springs to suit the mk 2 tunnel .
Some of the coversions you see.The rear seat squab sits too high.Hense the need for a trimmer.
You will also need a little filler panel either side of the rear back panel to window.
barry
Re Mk2 xj40 seat conversion
You do not need to cut the cross member the trimmer i used cut the spring
on the rear seat squab around the tunnel.Which allows them to sit properly
you do not use the mk seat pins you will have to use the xj mount plates which screw to the body.
My trimmer them re-welded the springs he had cut/reshaped so as to retain overall strength and to prevent sagging.
also the rear needs a little persuasion to fit ie reshaping the springs and a filler panel either side.
hope this helps.
hope this helps.
hope this helps.
hope this helps.
Hi,I find this most interesting . What modifications are required to fit the front seats. I would like to discuss this subject with you at some length.
I could supply my email and then phone ??
If you agree that is
barry
FS[NorthEast]: 2008 XJ Super V8 - Black on Cream
sg997tt
10-09-2015 10:57 PM
