‘92 V12 S3 interior light stays on no matter what
In this forum there have been questions with the same subject/problem. I’ve read most of them and tried the solutions suggested there on my own car, a LHD European spec car from 1992. The interior and puddle lights are on all the time. Pulling fuse #3 will kill the lights but also the radio, aerial and the electric mirrors.
I checked the aerial motor and pulled all the leads from the relay. I pulled all the doorswitches from the pillars and checked them and ground with a PowerProbe. All seemed normal. If I engage one of the door switches I notice a slight increase in light intensity of the interior and puddle lights. That is also the case when pushing the interior lighting switch.
I have tried to make any sense of the electrical diagram. As far as I can tell from this diagram 12V power comes from the top to fuse A (fuse #3 I presume) and goes from the fusebox to a connector C. What I find puzzling is key switch 38a which is said to be part of 38, the ignition/starter switch. What is its function? 20 = puddle lights, 280 = interior lights, 59 = interior light switch, 21 = doorswitch, 335 = interior lights delay BUT ONLY UNTIL 1983 so not on my car.
If all would be normal and I pull one of the doorswitches and measure voltage on this switch what am I supposed to see? 12V on one end end ground on the other but 12V on both when switched is engaged (door open)?
How is fuse C integrated in this diagram? Does it feed 12V to the same interior lighting harness as fuse A?
Thank you for thinking with me and hopefully shed some light.
Olav.
Olav.
Received 10,989 Likes
I'll have a look at my diagrams later and do some mulling.
I think your diagram might be confusing the issue. First, when the delay unit was eliminated there were changes to the circuit that I don't think your diagram shows. There were more changes in 1986-87. And, since yours is such a late car, I wouldn't be surprised if Jaguar made yet more changes. Tech info/documentation is very scarce for the late cars
If the book is nothing to go by how should I proceed. Whatever the layout, there is an unintentional ground somewhere. Is that after the interior light, either left or right, up until the doorswitch or could it also be in one of the doors after the puddle lights. If one puddle light makes ground do all interior lights stay on?
If all would be normal and I pull one of the doorswitches and measure voltage on this switch what am I supposed to see? 12V on one end and ground on the other? And 12V on both when switched is engaged (door open)?
Another ground issue has arisen. The brakefluid level warning light is on even when connectors to the fillercap are disconnected. Same symptoms. As far as I can tell the wires black/yellow and black run all the way to the rh side of the firewall and go through it into the cabin. That is where I lose track but am very hesitant to dismantle the entire dashboard. I find that scary.
Door open (switch plunger out)
Both side of the switch are ground
Door shut (switch plunger in)
One side of the switch ground, the other side 12v "+"
I was convinced that the unintentional ground had te be somewhere behind the facia and I was in no way going to take that apart. The brake fluid warning light was also playing up and 12V could no longer be detected at the brake fluid level switch. I traced the wites down from the switch all the way to the rh side of the engine bay. The yellow/black wire runs against the bulkhead from left to right and disappears into the cabin by means of the three white rubber connectors mounted right of the abs unit. From the connector to the brake fluid level switch there was a good connection. So I gave up. I would remove all 6 lightbulbs in the interior and that would be it. Reinstall fuse #3 and the radio and antenna would work again properly. I started on the rh side and when the 3 bulbs were removed I shut both doors to work on the other side when I noticed the interior lights going off. Reinstalled puddle light front right door; all still ok, reinstalled b pillar light; all ok, and finally the puddle light from the right rear door was the culprit. The fault was either in the bulb holder of which the contacts were mangled or it was the speaker nit being connected and the contacts hanging loose. Strangely the brake fluid level warning is now ok too. Don’t ask me why.
Thank you for thinking with me here. I hope this will be usefull for anyone else in the future.
Colin62mk2
06-08-2022 11:12 AM
bennett15ify
02-06-2022 07:34 AM
