1974 jaguar xj12 smoke problem
Received 10,871 Likes
Hello!
Thank you for the answer.
I bought this beautiful car two years ago from U.S.
From the begining the car was overheated.
I changed both thermostats , water pump ,all the water hoses, i rebuilt the carbs, i cleaned the radiator and many other things.
when i got the car from the engineer the car was running very well,the temperature was very well but the car started to smoke from the left side exchaust and smelled gas.
When i got back the car to the engineer he told me that water may pass into the engine.And he showed me in that exchaust that with the gas is coming out drops of water.
Is it possible ?
The smoke is black and it smells a lot of gas.
thank you
alex-john
Is it possible ?
thank you
alex-john
It IS possible for engine coolant to enter the combustion chambers and exit the exhaust, yes. This could be from a leaking head gasket, cracked cylinder head, or defect of that nature
However, water is also a natural byproduct of internal combustion so water vapors can accumulate in the exhaust, condense into liquid, and exit the pipes as actual water droplets. As a rule, though, this would disipate after the engine (and exhaust pipes) have thoroughly warmed up.
I would find a carburetor specialist to help with the black smoke problem
X_Type_South_Africa
12-09-2015 05:37 PM
Fraser Mitchell
10-01-2015 04:06 AM
