1975 Jaguar XJ6C differential
His location is Saudi Arabia. You're probably looking at having to source one from Europe, which won't be cheap to ship. They are not that bad to rebuild, assuming the ring and pinion gear are serviceable. All the bearings and shims are available. A different matter if you want to change the ratio.
Hi Gent,
No problem for me the location.From state or Europe.I need complete differential overhauled or in good condition.
Just direct me to the guy who has one.
By the way, mine, the differential is corroded badly internally. and lost metal from housing internally plus the pinion and gear.
This guy specializes in rebuilding Jag differentials, but I'm not sure if he can sell you one outright: Axle & Differential Overhauls
Ward Engineering in the UK are very good rear axle people, rebuild diffs and will source you one and rebuild it too. But first determine what ratio your current diff is, as ideally that is what you need to find, or something very close to it.
The very best reconditioned brake calipers, jaguar axle componenets, hubs, differentials superflex polyurethane bushes also wheel bearing kits, drive shaft ujs, cobra axles for dax, ak,
Best thing is to call them and explain what you need.
