1975 XJC floor pans
Received 9,472 Likes
Floor pans and a few other body panels are here:
Jaguar XJ Coupe Body Panels
I got parts from Rock Auto, eBay, Amazon, Summit Racing, NAPA, Welsh Enterprises, shop4autoparts.net, Parts Geek, SNG Barret, Speedway Motors etc.
Basically, parts are where you find them. Husband had little trouble locating everything we needed. One thing's for sure, Google knows where All the parts are for these cars.
Speaking as an experienced coupe restorer there is probably more rust than just the floor pans. Have a good look at the rear seat pans, inside the rear quarters, front jack point / kick area and check the rear frame rail.
If you find more tin worm... I would source rust free series 3 parts car that is worn out or has a bad motor and cut it up. This way you will have all the metal you need. 70% of the body is exactly the same or same and improved. I've done exactly this and would do it again. The parts unique to the coupe are either not available or very expensive so they may have to fabbed up.
The following 2 users liked this post by icsamerica:
awaj (08-08-2016),
olivermarks (02-11-2018)
Thanks, that's exactly what I thought I would hear, that the parts aren't readily available and that I would need to fabricate them. Mainly, because I only heard crickets on "the internets" when I went searching for parts.
Yes you are correct. I've only seen photos but the rear seat pan is gone and the left rear quarter has rust peaking through it right in front of the left rear wheel. There are two basket cases within a hundred miles of me that I could pick up, maybe one of them has good floorboards and footwells.
FS[Western US]: Parting out 1997 XK8 convertible
BobRoy
49
09-18-2016 10:48 AM
buickman
01-01-2008 11:28 PM
