1976 XJ12 Starter Wiring
I"m finishing up the starter on my Series 2 XJ12 and I need some help on where these last two connections go.
I have the trigger wire connected to the new starter, but my replacement gear reduction starter only has one post (for +12v). On the old starter, there was a wire coming from the firewall area (looked like it went up to the battery tray area-ish) that was tied together in a bracket with the trigger wire, and connected to one side side of the solenoid. When installing the new starter, I completely forgot about the wire that runs inside a conduit alongside the block to the starter, is this another +12v connection or is this another ground? If it's +12v, do I just connect it and the other wire together on the same stud?
The wire in the conduit you refer to connects to the alternator. This connects on the starter motor to the same post as the 12 volt feed from the post mounted on the firewall near the battery. The yellow stud/ post you have highlighted is used purely to attach a clip that holds the cable in place. The new starter should be easier to install, certainly a lot lighter!
Greg in France (11-10-2022)
The following 2 users liked this post by Scd:
BuckleSpring (11-09-2022),
When attempting to crank, the short ~1.5 foot cable from the positive battery terminal to the firewall stud gets rather warm, and a voltage drop measured at the starter with no cranking. Maybe the cable from the firewall to the starter was overheated at some point and/or has high internal resistance?
Received 2,399 Likes
Yellow series3
08-02-2022 05:55 PM
retroren
10-18-2021 01:18 PM
retroren
10-15-2021 02:19 PM
