1981 XJ6 been sitting awhile, What to do?
Old 02-20-2016 | 08:30 AM
Hafrod's Avatar
All four the same size. Got them on ebay as a set of four
  #82
Old 02-21-2016 | 11:05 AM
slofut's Avatar
Originally Posted by Jose
What is the size of the two outer headlights?
Those are 'mercan version 5 1/4 inch outer beams with afterthought filler bezels. Only brit cars had the proper 7 inch outers. Conversion in order...
  #83
Old 02-21-2016 | 11:06 AM
slofut's Avatar
Hafrod, did you get the fuel issues sorted out?
  #84
Old 02-21-2016 | 11:28 AM
Hafrod's Avatar
I bought a rough and rusty running/driving parts car for the fuel tanks. The fuel inertia button was tripped on the no fuel pump power.
  #85
Old 02-21-2016 | 11:34 AM
Hafrod's Avatar
My water pump came in Friday and waiting on some valve shims. So a good 4 day weekend, I should be able to get it out for a real highway test drive. I did notice when I backed out of my driveway, I heard a howling sound coming from maybe the rear section of the car. I was actually giving it some throttle while backing up. I don't hear it just idling backwards. Its only while accelerating in reverse. Anyone got any ideas? This car has sat for at least 5 years. Driving around my neighborhood, the forward gears are fine.
  #86
Old 04-29-2016 | 11:32 AM
Hafrod's Avatar
I had taken a break on my XJ and pulled the cover off last weekend. Tried to start it and no fuel pump power again. Pressed the inertia switch again but it was not tripped. I hot wired it with a jumper wire on relay and it started. I had shimmed the valves to spec but it still clatters and installed the hold down kit. Its not the fuel injectors clicking. The oil light is on at idle but goes off on a rev up. It left a big oil spot on the ground so after much thought, I'm going to convert it to V8. I have a rebuilt 350 engine and a rebuilt turbo 350 trans in my garage from a past project. I have been building street rods since 1992 and love fabrication. Very well versed in the old Chevy small blocks. I ordered a conversion book and plan on doing everything clean. I will also replace the factory gauges and senders with Classic Instruments. If anyone from this site wants a FREE 4.2 engine and trans, come and get it. I live in Verdigris OKLAHOMA.
  #87
Old 04-29-2016 | 02:36 PM
JagCad's Avatar
Hafrod>
Whose book? Three good ones out there.
In another forum, we helped a guy sort out the power plant for his
scratchbuilt "woody wagon". Low to the ground. Fantastic wood skills.
Power: 4.2 XK car'd engine with the original BW!!! first version, too low. Raised it with 19" Model A ford spokers.
It's exhaust was a teeny glass pack right of the manifold and to the side. No tail pipes at all. Too bad, inever got to heat what that critter sounded like.
I had to give my wounded 4.2 and sound BW away. No takers to buy it.
My lump purred on it's 30 minute trip to a nearby town to my Dos's office. VA clinic. We both are fine....
Carl
  #88
Old 04-30-2016 | 10:53 AM
Jose's Avatar
go for it, make it a a 4 or 5 speed transmission too. Unfortunately OK is way too far but I have a 1984 Vanden Plas parts car for free too and no takers.
  #89
Old 05-02-2016 | 12:55 PM
Hafrod's Avatar
I just ordered my kit from Jaguar Specialties. It was more than I wanted to spend but want it right and clean on the install.
  #90
Old 05-02-2016 | 05:02 PM
Andrew is a nice guy, knows his stuff and is very helpful.
When Nix gets a new engine/trans I plan to buy the trans mount from him to replace this one that seems to be made of bed rail. Such a cobbled up piece of junk I haven't seen in a Very long time.
  #91
Old 05-03-2016 | 10:16 AM
JagCad's Avatar
Got dumped in mid posting!! Here and the other Jag forum!!!
Hafrod: Great choice. Andrew is a good guy. Lots of jag knowledge.
willing to share it. Helped me a lot, even though, I bought the kit of another. I needed that help, no question.
LnrB;
Whaoh, bed rails are a great source of material for project. Abunbdant. Inexpensive and often free. The steel is usually
pretty good and cuts and welds well. I've used many.
In a past trailer project, I needed some tube steel.
Two angle iron bed rails arc'd together did it. That project
went way beyond "project creep".
Carl
  #92
Old 05-03-2016 | 02:42 PM
[QUOTE=J...
LnrB;
Carl[/QUOTE]
Yes, I know, Carl, it was the favorite raw material on the farm because they were CHEAP, high quality iron, came in standard, predictable dimensions and were Very strong. Husband even has a few pieces here.
However, a Much better thought out trans mount could have been fabricated, one that allows normal sized hands (mine are small) to reach in and check things like wiring, speedo connection, stuff like that. I wasn't kidding when I said it was a cobbled up mess.
  #93
Old 05-06-2016 | 08:42 PM
Hafrod's Avatar
Today I started weeding out my wiring in the engine compartment. Going to be rerouting and hiding. I worked on it all day long and got very familiar with wire colors and what they go to.
  #94
Old 05-07-2016 | 08:29 AM
Roger Mabry's Avatar
Default Best trans mount for clearance and easy to make
Jaguars That Run had their trans mount that I "modified" on my old SII... allowed for the most room around the trans...plus it allowed the dual exhaust to have a
home as well.
Just use Grade 8 bolts, nuts and washers...note the deep pan on the 700R.. DO NOT USE ONE...use a trans cooler instead as it reduces the ground
clearance on a Jaguar too much. The bolts in the photo were too long and were replaced with shorter ones later on...
Attached Thumbnails 1981 XJ6 been sitting awhile, What to do?-jtr-trans-crossmember-exhaust-cut-outs.jpg   1981 XJ6 been sitting awhile, What to do?-01010012.jpg
LnrB (05-07-2016)
  #95
Old 05-07-2016 | 09:18 AM
Thank you, Roger!
My 700 does not have a deep pan like that.
That mount is Simplicity itself!
Saving pictures in my Jaguar Documentation folder.
centarian07
11-29-2015 04:41 PM
MarkZ28
11-21-2015 02:00 AM
iownme
11-19-2015 02:27 PM
kmarajh
11-16-2015 09:29 AM
Misterbusy
11-16-2015 05:36 AM
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
Quick Reply: 1981 XJ6 been sitting awhile, What to do?
