1982 Jaguar XJ6 issues new advice/help
So my xj6 has a new battery, alternator, fuel pump, fuel filter, spark plugs, and volt regulator. Recently the car stalled on me. I got it back home, then it would start and then die. It seems the pattern lately is that if I leave the car alone all day it will start up and idle fine for about 15 mins then start giving up and die. Then after that it starts up everytime then dies right away. I checked all the air duct work and everything is tightened fine. I checked the fuel pump while the car was running and it makes a loud noise like humming but isn't that normal? It is a Bosch and is brand new. I do although sometimes hear a pop or two coming from the gas tanks when I shut the car off. One day I noticed gas leaking from my hose that connects to the charcoal canister but it hasn't ever done it since. All the meters check out on the dash. Could it be a bad check valve causing too much pressure in the lines and causing a stall. I also get the effect of seeing a gas tank get more gas than what it was actually filled to after filling up and switching tanks a couple times. Could a bad switch in the lines cause a stall somewhere? Im here in Ohio and its pretty cold up here now. Any suggestions or a list of things I should be checking? Thank you
Received 10,918 Likes
It was dark out and didn't have a light (phone was dead). So I stuck my hear to the gas tank and after shutting it off I can hear liquid being moved around so im assuming it returned fine but I will check tomorrow and look in the tank. Isnt it normal for the fuel pump to make a noise when you open the trunk and listen? Sometimes it will idle fine and then once I put it into gear it will definatly loose some power and even die. By the way this is the 3rd fuel pump I had replaced within 3 months.
Normal for fuel pump to hum. If it's more like a growl....then you might have a problem.
Repeat fuel pump failures are often caused by contaminated fuel. Pull your fuel filter and empty it into a clean container. What you see will dictate your next steps. I know your filter is new or almost new but if you have rusty fuel it'll start plugging up a new filter right away....and also cause the fuel to make more noise due to the resistance of the clogging.
Bad part is that the pump is *before* the filter...so any rusty/watered down/cruddy goes thru the pump first, and can damage it!
Received 2,399 Likes
Doug (01-16-2015)
Hi Doug, I really don't understand my car lol. This morning I went out and started it with no problems. Let it sit idle for about 10 mins and the rpms went a little low like it was giving out for about 5-10 seconds then returned to normal. Was able to drive it around the lot for a minute then got it back to my driveway. Didn't take apart the fuel filter yet, could this be maybe a sign of some bad gas or bad sediments in my gas tanks?
you don't have to remove the tanks to clean them, just remove the drain bolts at the bottom of the tanks, remove the chromed gas filler assembly at the top and stick a garden hose with good pressure in the tank, moving it around, then do it again from the bottom hole up.
let the water drain and dry overnight or more, you can use a garden blower with attachment to really dry them inside, then seal them back, add a can of STP Water Remover, fill the tanks and go driving until you use all the gasoline.
I have two Jags with twin tanks and that is how I clean mine every couple years.
