1982 xj6 ac low pressure port
I am trying to locate the low pressure port on the air conditioning system in order to retrofit it with 134a. There is no port up by the firewall as I have seen elsewhere on the web. Perhaps it's on the back of the compressor? Can anyone tell me it's location?
Hi David, Thanks for the pic. Problem is that there are two connectors on mine right where the arrow is. The two fill connectors are inches from each other.
Is the low side fill the one that comes off the fuel cooler --> hard line right to the back of the compressor or the other one?
If you look at compressor from rear, then the low pressure fitting is the one on the left.
Rgds David
Rgds
David
Rgds
David
![](https://cimg1.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/512x512/low_pressure_e294e235ba1d6466b277d2694eb592525416100e.jpg)
R134a Low Pressure fill fitting
![](https://cimg2.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/512x512/high_pressure_ce1e3856472e704f834874115418961a174e9ace.jpg)
R134a High pressure HLPS switch
The following 2 users liked this post by David84XJ6:
Doug (06-24-2019),
yachtmanbuttson (06-25-2019)
arnottdoug
04-14-2016 11:14 AM
