1983 Jaguar xj6 fuse diagram/ or help with lights
Received 10,930 Likes
Assuming the lights in question simply don't work and the bulbs are known good......
These problems are almost always caused by bad grounds, dirty/corroded connectors, dirty/corroded bulb sockets. The grounds for the marker lights on the fenders are especially vulnerable to the elements.
Here's some reading:
Parking/Marker Lamp Circuit Checklist
Post back for more details if needed
In the quick links there are links to all the service manual chapters. Included is a section on Electrical that contains wiring diagrams. It is this one:
Wiring Diagrams S57 Ser111 XJ6 (kindly supplied by Doug)
you need to disconmnect the battery, then go to the engine bay fuse box (next to the coolant tank), there are 5 fuses there, 4 for the front headlights, 1 for the auxiliary electric fan under the bumper.
once the battery is disconnected, clean the brass fuse holders of any corrosion, and close them so the fuses fit tighter.
Done.
Done.
Done.
Done.
^^^ This should be part of the 10-year routine service list
But, the tail lights and marker lights are on different fuses !
defnotlurkin
04-24-2016 11:14 PM
wnlewis
XJ40 ( XJ81 )
02-09-2009 10:47 PM
