1983 XJ6 blinker problem
Received 2,399 Likes
jarhead67 (09-04-2017)
Received 10,936 Likes
If all the blinkers simultaneously work and then don't work, I agree with Carl. A dud flasher is a very likely suspect.
If it's more of a case where some work, and some don't....it might be something else.
As with all electrical problems checking and cleaning all relevant electrical connections before replacing parts is a good practice. For example, you might pull the flasher and examine the pins and sockets for corrosion.
