1983 xj6 fuel injectors won't spray
These are all the things I have tried:
- No Injector pulse when ignition is turned on
- Inertia Switch
- Wiring injector harness
- Power Resistors
- CTS
- TPS
- ECU
- Injectors
Doug (03-10-2022)
The EFI system relies on a pulse from the ignition system. There is a wire, (I forget the colour), which goes from the coil negative terminal back to the ECU in the trunk. Basically, no ignition pulse = no injector action, the powered-up fuel system just sits there waiting for these pulses. Simple.
Fuel injection and the Jaguar XJ6 4.2 Series 3 / AJ6 Engineering
Doug (03-10-2022)
Received 10,899 Likes
