1984 Jaguar XJ6 4.2
i need some help car has a no start condition it has spark from the coil injectors has key on and cranking power but i am not getting the ground pulse from the computer and there is a white with blk stripe wire that goes from the negative side to coil the ecu and i am getting that signal to the ecm any help would be great and i also tried another computer from a parts car i have
Received 10,871 Likes
AJ6 Engineering has a 6 page study which is worth reading. No Start conditions are explained.
Fuel injection and the Jaguar XJ6 4.2 Series 3 / AJ6 Engineering
Andy Paine (01-26-2019)
I'd also have a quick read of Doug's excellent "Cranks but won't start" checklist, here:
ENGINE CRANKS BUT WONT START Series 3 XJ6
And since you have a parts car nearby, swap out the red pektron diode and the power resistor (DAC1211) on the RHS fender well...
I'm in NC too, near Salisbury...
David
shop.EverydayXJ.com
David
shop.EverydayXJ.com
Junkyardjohn (02-08-2019)
LnrB
11-01-2018 06:52 AM
