1984 xj6
Old 04-27-2013, 09:41 AM
trymes's Avatar
Roman: please start a new thread specifically about your problem (and with a descriptive subject). You'll get a lot more input that way.
Also, I think that an '88 XJ6 would be a an XJ40 model, but others can verify that.
Tom
  #102
Old 04-27-2013, 03:52 PM
Paratrooper54's Avatar
Originally Posted by trymes
PT54 (What's your name, anyway?): I know what you mean, but past experience has shown me that threads like this become more cumbersome than you expect, and actually make it harder to find the information you are looking for. More importantly, as time goes on, only those people (like me) who are already participating in the thread will chime in, as others just aren't likely to invest the time to read it all. This means you'll get fewer good opinions and ideas. In the end, more, shorter, well titled threads will get you the best results.
Either way, if you haven't seen this information on Stromberg Carburetors, you should take a look: TR250/TR6 Carbs Part I
Tom
You make a good point, I'll do that in the future when I have another problem...I forsee a lot of threads from me when I get to my 1972 XJ6...it needs a lot of work.
  #103
Old 05-31-2016, 10:11 AM
Candology's Avatar
Default Ac?
Originally Posted by Paratrooper54
The owner accepted $2,750 I'm the new owner of a 1984 Jaguar XJ6! You guys should see me here around a little bit more often now.
My father inlaw just got an 84 jag xj6.
Any idea how to open the center ac vent??
Center ac vent seems closed and can't find a way to open it.
Please help!
  #104
Old 05-31-2016, 12:02 PM
Jose's Avatar
Received 2,461 Likes on 1,850 Posts
it opens only during a/c operation, TEMP knob at between 65 and 75.
then it opens by vacuum, each Dash vent has a Vacuum Actuator. And each Blower Case has one too, yes there are two Blower Fans, one on each side, driver and passenger sides.
you might have to remove the Dash Cap to confirm the actuator nipples or "ports" are connected to blue color plastic tubing, (sometimes white or black).
  #105
Old 05-31-2016, 01:03 PM
Received 9,382 Likes on 5,440 Posts
Default Just Prop It Open!
My center vent didn't work since I got the car.
One of the first things I had to fix was the blowers, so, as I was in the area anyway I took a look at the workings of the center vent.
After a thorough investigation which included calculating how much work and expense would be involved in a "Proper" repair I decided to Cheat and just prop the thing open.
I cut a piece of 20ga. galvanized sheet metal and bent it so it straddles the fins inside the structure.
I cut the forward legs at a slant for ease if insertion and removal. I take it out in cooler weather so I have more heat on my feet, and more air through the demist vents. The legs are long to minimize dropping the thing down in the guts of the climate control.
Here is a close-up of the propped open vent.
trickeyM
10-04-2015 05:43 PM
wonderwire
10-04-2015 05:41 PM
baskervillema
10-01-2015 06:43 PM
dansxj6
09-28-2015 08:02 AM
42Ajd
09-26-2015 07:04 PM
Quick Reply: 1984 xj6
