1985 XJ6 wipper no turning
On the other side of the motor there is a pair of cover plates held on with 6 small screws. Remove the screws and take off the plate. Then you can unhook the end of the control cable from the wiper motor gear wheel.
Here is a page from the parts book showing the motor, which might help to make it clearer:
why not substitute the motor from the other XJ if the wipers are working in the other car?
Removing the wiper motor:
remove the half-moon bracket around the motor case two 7/16 bolts
pull the motor out from the cavity and VERY CAREFULLY pull the wiring plug from the motor.
To release the cable:
remove the 4 hex screws from the motor cover, they are 1/4" inch screws. Keep the motor facing up in your hands
loosen the thumb ferrule nut from the motor. you might need pliers,
pull the cable off from the pivoting Cam.
drdrummerii
05-20-2013 10:18 AM
