1986 XJ6 Left Side Windows Not Working!
Received 2,643 Likes
The simplest way to diagnose where the fault lies is to remove the switches from their place in the console and swap them with the ones that do work. Rather than replace the switches, it is possible to disassemble them and clean the contacts with a pencil rubber (eraser) to remove any deposits or corrosion. Just be careful not to lose the springs.
Received 10,912 Likes
Switches are a common fault and, as mentioned, they can be cleaned to restore proer operation in the majority of cases.
However.....
In your situation I'd swap the two circuit breakers and see what happens.
Power for the windows and sunroof comes from the window relay. Output from the relay branches off to two circuit breakers. One circuit breaker power the right side windows; the other power the left windows and sunroof.
Since your left windows and sunroof are all inoperative I'd be tempted to suspect the circuit breaker.
The breakers are on the right side compnent panel, about 1" square, with two spade terminals. Each one will have red/slate wires. Just swap them over...or swap the wiring over.
If one is faulty it can replaced with a generic 30 amp breaker from the local parts store.....unless you wanna spend $50 for a Jaguar original :-)
I've seen some cars where the breakers were replaced with simple inline fuses.
If the new breaker trips or fails you'll have to trace a problem in the circuit.
However.....
The circuit breakers for both left and right windows are found on the right side component panel., below the fuse box, as I recall. They're mounted right next to each other. Remove the right side under-dash trim panel for access.
To clarify, both left and right side power windows would work if using the right side circuit breaker, correct? And none of the windows would work if using the left circuit breaker, correct? if so, it sounds like the left circuit breaker is dead.
So Im not sure where to go from here now?
Here's a typical/generic power window circuit breaker
Corvette Power Window Circuit Breaker, 1979-1982 - Corvette Parts and Accessories
Ok, both circuit breakers are OK, got it !
Well, I'd say you have a A) break in the wiring downstream of the circuit breakers B) or several inoperative switches or C) three dead motors
On GP you can remove the switches and clean them as previously mentioned.
Do you have a 12v test light? Or volt meter? Should be easy to see if the switches are getting supply voltage.
You can also apply power directly to the motors via a 'jumper wire' to see if the motors work, but more than likely it's either a switch or interruption to ground that is the problem.
When you begin reassembly of the switch, be sure the springs are in their proper positions before seating the pins on the side of the switch button back into place.
With a vehicle that is now thirty years old, anything is possible. Use a test-lamp and determine if you have power to the switches with the ignition in the 'on' position. If there is no power to the switches, there is a problem with the wiring and you will need to trace where the fault is using the wiring schematic for that year vehicle. If the vehicle has been operated in an area with corrosive salt used during winter months, there is also the possibility of corroded connectors or faulty ground points. A previous post in this thread mentioned the location of the ground point for the cigar lighter, windows and other accessories.
Check for "+" voltage on the red/slate wire at the sunroof switch and the left front window switch.
If no voltage you have an upstream problem (broken wire, loose connector, etc) between the circuit breaker and the switches.
If you DO have power at these two switches then clean the switches as described...which should be done on general principle anyway, given that they are known to be trouble spot.
I'm away from the diagrams at the moment but as I recall power to the left rear window switch comes *from* the left front window switch. SO.....if you have votage to the left front window switch, clean that switch and see if the left rear window switch gets power (the wire color changes....can't remember the colors)
As mentioned, though, anything can happen on these cars :-)
To recap: 1) check for voltage supply to the switches. 2) Check the ground wires ner the gearshift. 3) Clean the switches regardless of what you find. You'll be glad you did :-).
Ok so I took off the wire from the switch to the rear left window and then the driver window and sunroof would work, but when I pug the switch back on all 3 stop working and the relay makes a clicking sound every few seconds. Very strange but I kept that plug out since that window is already up and now I can use the driver window and sunroof plus the right windows.
