1987 XJ6 4.2 Gearbox problem!
Received 10,941 Likes
Do you mean the gearshift physically won't allow movement into 1,2, and D? If so I'd suspect a broken or binding shift cable or other problem related to the shift cable...such as the underbody bracket the holds the cable being broken.
Or do you mean the transmission operates only in reverse...but won't move the car forward in 1,2, or D ? If that's the case I'd suspect low fluid and/or loose bands.
Well, they don't last forever.
But....adjusting the bands will sometimes bring 'em back to life. If you wanna DIY I can provide info. It's isn't very hard to do....and it's free.
Here's some reading on band adjustment
http://www.jag-lovers.org/xjlovers/x...ansxadjust.htm
KarimPA
09-03-2015 07:32 PM
Chet Ramnarain (bozzner)
09-03-2015 12:21 PM
