1987 xj6 no injector pulse
Received 10,862 Likes
A couple EZ checks before getting into anything weird:
- There's a white/black wire from the coil "-" post that runs aft along the water rail. This a the trigger wire for the fuel injection. Check the wire and connections
- At the rear of the water rail is a bundle of 5-6 ground wires. These are the grounds for the entire fuel injection system. Make sure none are broken and the ground connection isn't corroded
- On the RH inner fender, down low and well forward, is the resistor pack for the fuel injectors. Silver box, about the size of a pack of cigarettes. A little tricky to reach. Check connector plug and pins for corrosion.
The cold start injector (which operates 100% independently from the regular injectors) should have power (that is, 12 volts positive) only when the key is turned to 'start'. If it has constant power, something is amiss....although probably not related to your primary problem of no power to the injectors.
To clarify, since I may have misunderstood, you've verified that there is no voltage supply to the injectors? Or, simply, the injectors are not operating?
Voltage supply to the injectors comes from the 'main relay' on the firewall and thru the resistor pack.
OK, some quick voltage tests at the main relay
- White wire should show 12v with key 'on'
- Brown wire should show 12v at all times
- Brown/slate wire should show 12v with key on
- Black wire is ground
Assuming that's all OK go to the resistor pack and check for 12v at the brown/slate wires with the key 'on'
As for 12v at the cold start injector has someone replaced the red diode pack with an ordinary relay?
However, since we're here, the checks for the starter relay are:
- solid brown wire = voltage supply, 12v at all times
- black/green = should be ground with transmission in P or N
- white/red = output to starter solenoid, 12v with key turned to start
- white/yellow = trigger voltage from ignition switch, 12v with key turned to start
- white/blue = not used/needed, ignore, but should be 12v with key turned to start
On the firewall you should have the starter relay, a red diode pack (for the fuel pump circuit), the fuel pump relay, and the main relay. For a 'no power to injectors' problem you should focus on the main relay. The main relay sends voltage to the injectors and the Air Flow Meter, and powers-up the ECU. I know you swapped it out with another and there was no change but that doesn't prove that the the relay is being triggered. A couple posts back I described the checks for the main relay. Or, just check for 12v at the brown/slate wires at the injector resistor with the key on. If you have 12v here then you know the relay is being triggered
On these old Jags a solid brown wire will always be constant 12v "+" and, one way or the other, go back to these junction posts. "All roads lead to Rome" type of thing.
All the solid brown wires eventually end up at one or the other of the junction posts.....and the posts themselves are wired together with a heavy cable hidden behind the fiber-board heat panel.
I say 'eventually' because a couple branches of the brown wire circuits have splices or additional junctions....but my memory is foggy on which branches, specifically.
So, if everything is OK at the junction posts you might have to look for a problem downstream. But the posts are 'square one', so to speak.
I suggest you download the S57 Wiring Guide. It's available in one of the sticky threads at the top of this section
Received 2,399 Likes
![Smile](https://www.jaguarforums.com/forum/images/icons/icon7.gif)
These are the "easy" wires. Start at the battery + post. trace the large cable to the firewall post. Many wires should be there. Caveat, if battery - post cable is not properly connected at the wing wall, you will have zero volts at the fire wall post.
Basic. Proper battery connections proper battery to ground connections .
And,as Doug knows these critters far better than, follow his guidance.
And, Aye, the post on the right side is connected to a similar post on the left side.
For more guidance. white wires are hot only when the ignition key is on...
Do you have the S57 Schematic. Sans it, you are flying almost blind...
I hope??
Carl,
I hope??
Carl,
i have a wiring dia but i don't think it matches car, colors diff, right on doug they had put a new battery in and messed up the wires on the post. now i have power on brown wire, nothing on other, seems to me if i have power on one wire then turn key on it should go across the relay to other brown. or am i making a mountain out of a mole hill? still no power on brown/slate. it's a 5 prong relay in a 4 wire place. doesn't make sence, but it works in the other 87 that i bowered to switch parts ,will try and get a diff wiring dia
None of the relays are intended to carry power from one brown wire to another brown wire.
A 5 prong relay in a 4 wire socket isn't a problem. The 5th terminal on the relay isn't used/need on this particular circuit.
