1989 xj6 stopped starting but will start and run with starter fluid.
Guest
Posts: n/a
I changed my oil in 1989 xj6 jaguar same way i always have .I went to start it up and all it would do is crank so i replace fuel filter, fuel pump,plugs and rotor ,dis.cap plus fuel regulator ,replaced battery .Still it only starts and run only if you clean throttle well or spray starter fluid in mas intake will run good with a little high idle when stopped now but when you turn off will not start again.Can someone please answer this crazy jaguar riddle for me cause other than replacing stepper motor or poteintmeter (throttle position switch ) i am at my wits end . thank you
1964Daimler
09-02-2015 11:41 PM
SingBlueSilver
08-27-2015 02:20 PM
