1991 XJ6 alarm buzzer will not shut off
Old 01-28-2010 | 01:10 PM
These jags have a whole host of methods of communication from beeps to chimes and shrieks.
Can you describe the sound in more detail?
The door ajar 'chime' should only sound when the lights are on and you open the door.
If you are sure that it is in fact the door chime you might want to check the door switch for obvious damage. Pull back the rubber boot and check for broken/shorted wires.
Give it a blast with WD40.
Are you 100% sure that your battery is good? A dying battery can trigger all sorts of strange happenings.
Do not cut wires, Jags don't like this method.
Cinny65 (05-21-2014)
Old 05-15-2014 | 12:46 AM
rrman03's Avatar
You alarm is losing the ground or shorting to the frame.Good luck tracing the wire.
hoodun
10-06-2015 09:52 PM
abonano
25
09-25-2015 11:43 AM
Chuck Schexnayder
09-18-2015 04:10 PM
eurotire
09-18-2015 08:27 AM
Bigvettefreak
09-06-2015 05:27 PM
Quick Reply: 1991 XJ6 alarm buzzer will not shut off
