1991 xj6 sls part
williamsmith1436 (06-17-2011)
If you have already had the SLS rear suspension converted to regular dampers then you can REMOVE the hydraulic pump for the 1990 to 1994 XJ40. You need to remove the valve block and all the related hoses including blocking off the return line to the reservoir.
The 1988/89 use the pump for power assisted braking.
bob gauff
bob gauff
Chet Ramnarain (bozzner)
09-03-2015 12:21 PM
