7" Euro Lights = Dead Battery?
So I recently bought an 1983 XJ6 and am in the process of doing cleanup and restoration. Last night I got to replacing the standard 5" headlights with the 7" H4 lights. To get the wires out of the old housing, i had to cut the wires and then splice them back together once in the new housing. Everything installed fine and both of the headlights we beaming beautifully. I even took the car down a dark road to enjoy the luminance. After the test drive, I parked the car for the night and went to bed. This morning when I tried to start up the car, the battery was dead. I tried jumping it for about 20 mins, but it wasn't enough time apparently. I'm assuming the battery is really really drained and needs more time to charge. I will try charging it for a longer period once I get back from work. Also, the battery was replaced about 3 weeks ago.
Any thoughts on what would of caused the battery to die this severely and quickly? Could it be because I snipped the wires and then spliced them back together and there is a loose connection somewhere? I'm thinking a poor connection shouldn't drain a battery, but I could be wrong. Any help or thoughts would be appreciated. Thanks!
OkieTim
09-08-2015 04:48 PM
