71 XJ6 tachometer not working
Hi everyone:
the tachometer is inoperative, and has been since we purchased the car (35k original miles).
The needle is pegged all the way to the right (redline), I do not know if this means anything. All the other gauges are working.
Any assistance would be appreciated, and thanks in advance!
Paul
Paul
Received 10,916 Likes
Received 2,399 Likes
Or, a lessor guess.
Most rely on the make and break of the distributor to create a pulse, in turn converted to mechanical movement. Classic electro mechanical technology. As it is the ground leg that is make and break, I would suspect it is grounded all the time, not off and on ground...
Find the ground lead to the - post on the tach. Disconnect it. Fire the engine. If it drops to 0, I got it. If not, Doug's theorem is most likely.
Carl
Carl
FS[UnitedKingdom]: 2005 XK8, 35k miles Excellent condition
CougCol
05-12-2016 01:52 AM
