'72 XJ6 rear brake overhaul
#41
#44
#45
On a side note, my centre console needed a bit of work as can be seen in this Picture.
![Name: 20140914_182907_zpsa6651b0d.jpg
Size: 55.9 KB](https://www.jaguarforums.com/forum/attachments/xj6-xj12-series-i-ii-iii-16/155284d1501211094-72-xj6-rear-brake-overhaul-20140914_182907_zpsa6651b0d.jpg)
The centre console and the front seats are out of a sIII, hence the gap between the console and the dash board tray. Anyhow, the ski slope had been modified by a PO to accomodate the B&M hammer shifter, but he had done a pretty bad job. I pulled it out, ripped off the leather and drilled some holes for a couple of cup holders and a Power outlet. I covered the ski slope with the same wrapping the rest of the car is wrapped in, and had a local upholsterer make me a new boot for the shifter. I had the console toplid recovered as well. Made a vast improvement I think!![Smile](https://www.jaguarforums.com/forum/images/smilies/smile.gif)
![Name: image_zps805neahb.jpg
Size: 108.8 KB](https://www.jaguarforums.com/forum/attachments/xj6-xj12-series-i-ii-iii-16/155285d1501211094-72-xj6-rear-brake-overhaul-image_zps805neahb.jpg)
![](http://i8.photobucket.com/albums/a15/Paganize/Mobile%20Uploads/image_zps2ckpk24r.jpg)
I still need to adress the gaps between the console and the tray, but that'll have to wait 'til another day!
Received 9,208 Likes
Aviator-Olav (04-11-2015)
#47
I had a bit of a set-back in my IRS project Monday last. As I backed the car out of the garage, brake fluid gushed out of a brake line on one of the calipers. I jacked it back up, and spent a few hours fiddling about with it. Time wasted completely, the fitting was stripped and there was no way it would come off with the IRS in the car. So I dropped it again. I wish I had done that immediately instead of fiddling about under the car for hours! It took me exactly one hour and it was on the floor
![Name: D22B864A-98E9-4F31-A5BF-6A5B6405B661_zpsaktsmwsp.jpg
Size: 178.7 KB](https://www.jaguarforums.com/forum/attachments/xj6-xj12-series-i-ii-iii-16/155159d1501210760-72-xj6-rear-brake-overhaul-d22b864a-98e9-4f31-a5bf-6a5b6405b661_zpsaktsmwsp.jpg)
New brake pipe installed.
![Name: 31486940-9DC3-4A07-87E6-005EDE04EC5D_zpsqak2ace5.jpg
Size: 124.4 KB](https://www.jaguarforums.com/forum/attachments/xj6-xj12-series-i-ii-iii-16/155160d1501210760-72-xj6-rear-brake-overhaul-31486940-9dc3-4a07-87e6-005ede04ec5d_zpsqak2ace5.jpg)
It took me about two hours to put it back in the second time.
Finally I could back the car out and enjoy it! Wrong! The exhaust made a terrible racket, and it was leaking all over the place as well. I bit the bullet and had a new exhaust fitted. Routed under the IRS. Thanks Roger Mabry for putting that idea in my head! 😊
![Name: 83E636D2-9F63-4EE8-9AD1-02A5157AB5C2_zpsqbrvboiq.jpg
Size: 262.8 KB](https://www.jaguarforums.com/forum/attachments/xj6-xj12-series-i-ii-iii-16/155161d1501210760-72-xj6-rear-brake-overhaul-83e636d2-9f63-4ee8-9ad1-02a5157ab5c2_zpsqbrvboiq.jpg)
My son loves the car! He doesn't want to get out!
![Name: D9C8B24F-8EFE-4300-840B-3E8B23C91475_zpsohsqufsn.jpg
Size: 177.2 KB](https://www.jaguarforums.com/forum/attachments/xj6-xj12-series-i-ii-iii-16/155162d1501210760-72-xj6-rear-brake-overhaul-d9c8b24f-8efe-4300-840b-3e8b23c91475_zpsohsqufsn.jpg)
That wraps up this project, I hope this thread has been helpful to some.
Cheers!
Tor
Cheers!
Tor
LnrB (04-11-2015)
#48
#49
I am currently replacing that rear valance with a new copy from SNG Barratt so I can exit the exhaust under the IRS in my '71 car instead of just
underneath. PO had the original holes filled up and welded shut! It looks too odd for a Jaguar that way... will use the curved exhaust tips.
I plan to use ball clamps instead of flanges for easy removal for servicing the IRS should that be needed again (mine is already done).
It is a shame that all our hard work and paint is not shown while driving down the road!
#50
#51
#53
Oceansidesurf (06-17-2016)
Currently Active Users Viewing This Thread: 5 (0 members and 5 guests)
