'72 XJ6 restoration/upgrade
Old 12-07-2012, 08:06 AM
icsamerica's Avatar
Received 1,363 Likes on 793 Posts
Originally Posted by tacamo
Have the 700R4 rebuilt and the entire front suspension including all bushings, ball joints, bump stops, sway bar mounts/bushings and steering rack bushings replaced. Still waiting for the adapter kit from Johns to begin the trial engine/trans fitting. Removed the front and rear glass and was most pleased that there was no rust in the channels. Car is virtually rust free! Hope Johns come through soon so I can finalize the engine and trans location in the chassis and start rebuilding the 5.3L before Christmas.
The car is a grey or silver color but I can't find a paint code anywhere on the body...any help?
Good to hear the car rust free, that's big! Post some picts.
Old 12-07-2012, 04:16 PM
Roger Mabry's Avatar
Default Check your front axles on the bottoms for wear
Thought I had all the front end problems repaired in my '71 S1, but found
wear on the front stub axles. It shows up on the bottom only and you can see the
wear in the photos...LF was worse on my car.
Attached Thumbnails '72 XJ6 restoration/upgrade-lf-most-wear.jpg   '72 XJ6 restoration/upgrade-rf-little-wear-1-.jpg
Last edited by Roger Mabry; 12-07-2012 at 04:21 PM. Reason: Forgot to attach photos
Old 12-07-2012, 04:57 PM
Fraser Mitchell's Avatar
Received 2,450 Likes on 1,948 Posts
This stub axle wear on the underside is very common. A lot of people have adjusted, (and ruined), the bearings due to not realising this kind of wear exists. I once replaced both sides on an XJ6 Series 3 I had. It was fairly straight forward once I had the stubaxle carriers removed. Undo the big nut at the back, (loosen off before taking the stubaxle carriers off), then apply a "talking hammer" to the stub axle with the carrier held up on two substantial blocks of wood, then insert new stub axles and put nuts back on and bolt up. Full torque can be applied when they're back on the suspension.
Old 12-07-2012, 09:21 PM
tacamo's Avatar
I have actually removed the entire front cross member and completely disassembled all the components from the front suspension. Everything was closely inspected and I saw no evidence of problems with the stub axles. Luckily I have a Brit race car fabricator looking over my shoulder on this project and he is pretty thorough. Thanks for the "heads-up".
Old 12-08-2012, 08:43 AM
SableXJ6C's Avatar
tacamo- What are you going to do with the triple Weber setup on that XK engine? If you want to sell the manifold/ carbs/ linkage, let me know.
Old 12-08-2012, 09:05 PM
tacamo's Avatar
Sable- the intake setup on my XK engine used 48mm DCOEs and in all honesty was not really a streetable arrangement in an XJ with the BW auto trans. It really needs an engine with considerable head and exhaust work plus a manual transmission. My engine lost compression on one jug and my plans were to tear the engine down, rebuild it for high performance use and sell it an a complete assembly to someone like a vintage racer. Looks nice but in all honesty it is way over carburetted for a stock street engine.
trickeyM
10-04-2015 05:43 PM
wonderwire
10-04-2015 05:41 PM
baskervillema
10-01-2015 06:43 PM
dansxj6
09-28-2015 08:02 AM
42Ajd
09-26-2015 07:04 PM
Quick Reply: '72 XJ6 restoration/upgrade
