77 XJ12L oil/trans pan gasket leaking
Received 6,327 Likes
Opened a nice bottle of Johnnie Walker,Explorers Club Collection and had a couple while watching a round of Moto GP, now just finishing the last of the Cab/sav I opened last night.
o1xjr (08-24-2014)
Received 2,399 Likes
Looking good.
Wow, that tin pan has taken some hits. But, I note you bashed it bak into close to what it should look like.
Tin pans have a way of becoming deformed around the bolt hoes. A raided edge around the circumference. it makes a seal tougher to get. With something on the other side, a few gentle whacks with a body hammer removes the bulge and allows the edge of the pan to contact the transmission case or engine block much better.
Carl
Carl
o1xjr (08-24-2014)
Doing it down under
I am new to this Jaguar forum, pick up my 74 XJ S2 next week, it has been stored in a garage since 1991 and has done less than 26,000 km.
First thing I intend to do is change all the fluids, so it was very interest reading in this thread and informative.
I have been a Jeep nut for a long time currently owning a 79, 99 & 2010 models
The 79 is currently under going a full restoration and have just stated putting back together (exciting).
But I have always wanted a classic car, was looking at MK2 3.8L till I stumbled upon the 74 XJ,
Reading about some of the cleaning fluids you Guys are using made my dormant cancer cell starting to cheer.
My normal way of cleaning auto, diffs, thermostat housing etc is to peel of most the crap with a scraper (carefully) then use my Dremel or battery drill with a soft wire wheel and buff of any crap left then use a medium fine wet & dry sandpaper to finish of the pan. If I have to use the wire wheel on the auto or diff housing, I stuff them with clean rags first.
Look forward to talking too you in other threads
Hi cherren, another Jeep nut here. I just put my 95' XJ cherokee up for sale yesterday. After 17 years with the XJ we have decided to upgrade to a 2011-2013 Kk Cherokee.
That xj got me there and back every time.
As Grant said,post an intro thread . link below.
New Member Area - Intro a MUST - Jaguar Forums - Jaguar Enthusiasts Forum
#28
Received 9,248 Likes
aholbro1
08-05-2021 05:02 AM
Wes Steenrod
09-06-2015 06:52 PM
