79 XJ6 gas is changing tanks
Hi All, its been a while since i posted. Hope everyone is doing well.
I filled up my left tank today and saw it deplete quickly into the right gas tank. Then the car started showing signs of fuel starvation, lurching while driving like its going to die. Never did die and idles fine at the lights. What's my issue?
Thx.
Thx.
Received 10,875 Likes
Assuming you have a late USA Ser II with fuel injection or a very early Ser III.
My guess is that gas is being drawn from the left tank but being return to the right tank. Most likely a faulty return valve.
This might help
Fuel Tank Switchover Checklist, Series III XJ6
This might help
Of course you may have a blocked tank pickup filter as well. Many happy hours or even days can be spent on the fuelling system on these cars.
Did I say happy ?
In theory, it should be normal. However, it seems like these fuel tank changeover valves don't make a perfect seal, so over time, the tank levels will equalize (very slowly), so essentially it is possible, I suppose, to have your left tank overflowing with gas eventually, even when you are only using the right tank.
I solved this problem by replacing my changeover valve with a bunch of brass fittings. Now the car runs great and I never have to worry about the dual tank system! I just need to remember not to park on heavily crowned road...
Aplogies if you know all this already.
There are three valves and one switch controlling the fuel flow.
1. Changeover valve - found near the fuel pump, and swaps feed to pump from the left or right hand tank. This can sometimes stick on changeover when you least want it to. Quick fix is to give the valve a light tap with a spanner or small hammer to make it move. As this valve is buried behind a cover in the spare wheel compartment, doing this tapping is a real nuisance when the trunk is full !! As happened to me around 1992 coming back off holiday.
2. RH and LH return valves - found at the back of each rear wheel arch behind a cover, and are handed left or right. Each one has a default setting based on what side they are fitted. On one, power opens the valve, and spring closes it, and on the other, its the other way around, thus diverting returning fuel to one or other tank.
3. Changeover switch - on the central dash panel. These can fail and if they do the valves will be set incorrectly and cause chaos in the fuel circuit. Petrol can end up being sent to the wrong tank, and overfill it. I once had fuel flowing at quite a rate onto the road via the overflow pipe. Pretty scary !
Poor electrical connections can have the same effect as well.
Not to hijack the thread, but is there any real reason that a functioning dual tank system is better than just having a brass T fitting replace the fuel tank changeover valve? I guess drawing from each tank individually would probably keep the fuel fresher, but other than that, I can't really think of why the system exists in the first place.
If you look at the X350 like mine, it has a "saddle" tank with effectively two compartments, but has a system for keeping the fuel level in both sides using a "suction jet-pump". Of course, Jaguar started off with two tanks when they used carburettors, and there was no need for fuel return, it was put in when the XJ went over to fuel injection. Things move on, and now my X350 also has no fuel return, the pump pressure relief valve and overflow is back at the pump end.
As you will see here, somebody has converted to make it effectively one tank and hence avoid the problems.
FS[Western US]: XJS Lock Set with Keys- Doors, trunk, glove, gas, and ignition
XJsc-guy
11-23-2015 01:56 PM
KarimPA
09-03-2015 07:32 PM
Chet Ramnarain (bozzner)
09-03-2015 12:21 PM
