'85 Vanden Plas - Where is washer motor?
My windshield washer motor quit working after our local repair shop tried unsuccessfully to get my cruise control working. No sound when I press the washer button; I did check the fuse, but that is not the problem. My Hanes manual says the motor is mounted on the rear firewall, but I'm embarrassed to admit I can't find it -- can somebody point me in the right direction?
jpbmass (07-06-2017)
On your 85 it should be mounted in the lower part of the reservoir, as shown in the attached scan...
I can't think of a reason that the shop could have messed it up looking for a cruise control problem. It may just be unfortunate luck that it failed about the same time they were working on it.
David
shop.EverydayXJ.com
David
shop.EverydayXJ.com
David, I'm suspicious of the wiring because both the cruise control and window washer pump are activated by switches on steering column levers, and my local shop, while good with mechanical repairs, is notoriously bad with electrical issues. However, it is easy to put a meter across the inputs to the pump and check out the circuit. If it is the pump, is it just a press fit that can be levered out, or is it more complicated than that?
Jim
Jim
Received 2,399 Likes
My 83 seems to be configured differently. Not sure if it came that way or if an after market pump was fitted. No washing function.
I removed the pump, a simple little black box with hose fittings as well as electrical plugs. It bench tested just fine. But, my rewire must've err'd.
Point.
Bench test it. If no go, get one from David!!
If it works, go to the S57 Jaguar schematics. Easy to read and track.
Carl
Point.
Carl
Jim,
Yeah the pump is just a press fit into the reservoir. You do have to be cautious with the spigot on the pump when you remove it. If you pull it out at too great an angle it will snap the spigot. There's also a grommet on the reservoir that will leak if it's either torn or omitted when you reinstall...
Carl,
Both types of pumps were used on the Series 3. If you have the long skinny reservoir the pump is mounted next to radiator at the front of the car. That is on the car up to sometime mid 84... Then they changed to the later reservoir with the pump integrated into the reservoir at the latter part of 84... And of course they used different pumps just to make it interesting....
David
shop.EverydayXJ.com
Carl,
David
shop.EverydayXJ.com
jpbmass (07-07-2017)
OK -- I checked wiring to the pump and determined there is a 12v signal to the pump when the "wash" switch is pressed so my problem is indeed a faulty pump. I have the type of pump that is recessed into the reservoir -- I've removed the wires from the pump (to test) and will next remove the small hose that goes to the washer nozzle. From the picture you sent me, David, it appears that I should pry to the side of the reservoir to remove the pump (instead of up)? Is that a spring clip on top of the pump nozzle that I need to be concerned with?? I'm a little nervous about just trying to horse it out, but hey -- what's the worst that can happen??? BTW, there is an Advanced Autoparts store in our town that claims to have one of these pumps in stock for about $17 -- any reason why that shouldn't work as a replacement?
Jim
Jim
Received 10,871 Likes
Just to clarify....
The pump motor should have 12v "+" whenever the key is "on". Ground to complete the circuit comes from the pushbutton
Personally I find it easier to remove the entire reservoir (single bolt through the middle) and deal with prying the motor out on the workbench.
No clips that I recall....but I'm on my first cuppa coffee
Jim
Jim
Doug - Unable to remove the bolt through the center of reservoir; bolt turned but did not loosen -- must be a hidden nut on back side of fender not visible/accessible from wheel well??? Anyway, was able to pry out the pump so I guess it's a moot point, but am curious how to get this simple bolt out.
Received 9,203 Likes
Exactly.
One long arm reaching into the engine bay to attack the bolt. The other long arm reaching into the wheel well to hold the nut with a wrench. it's doable....but if you have short arms you'll need a helper
davidboger (07-08-2017)
