85 XJ6 Blower Motor question
1985 XJ6 Vanden Plas
blower motors stopped running all of a sudden, I have been reading all the posts I can find and trying to trouble shoot, so far I have checked the following
checked all fuses, 2 in fuse box have battery voltage, behind the left side of the console, and the right side, all ok
removed green/slate wire from the relay applied battery power, blowers both run
the screw on main lead on the relay has battery voltage
relay showed signs of corrosion on some terminals, replaced relay and cleaned connections
removed and connect the two wires on the heater core temp sensor, no change
the defroster flap still worked
while checking voltage on the brown, brown/yellow in fuse on the right side of the console and turning the fan switch, at off no voltage, when on only .6 volts while testing this the defroster flap stopped moving
does any one know what the voltage should be on the rt side inline fuse?
I'm thinking the switch maybe bad, if it is would it shut down the whole system?
thank you for any ideas you may have
Joel Moross (03-15-2016)
no easy solutions, it takes checks and more checks...and substituting parts.
1) easy check: substitute the large relay with another, (there are 4 relays inside it), (Number 2 in diagram below) > be very careful when removing and reconnecting the wires, it is critical they are correctly connected, disconnect battery before.
2) check the blower Resistor mounted to the side of the a/c case and above the large relay. If the "springs" look burned, it probably is bad. (Number 3 in diagram).
eurotire (09-12-2015)
Received 10,876 Likes
OK, good. Now you know everything downstream of the relay pack is OK
Good, That sounds like supply voltage to the load side of the relays
good.
It sounds like you are lacking *control voltage* to the relays.
With the mode switch set to 'auto", slowly operate the temp control. Do you hear the servo whirring?
Try bypassing the Ranco thermostat in the same manner and see if anything changes. Just follow the brown wires from the inline fuse you were asking about. The Ranco thermo is just a few inches above
I think it would, yes.....thus the question about the servo whirring
Saemetric (09-13-2015)
We did some more troubleshooting, jumped 12v to the brown / yellow wire on the relay, the fans work, change speeds, set to auto, moving temp control fan speeds change. So it must be the mode switch. Removed most of the center stack, but can't get the switch out. Picture of where we are disassembled to. Any ideas would be helpful.
You have to remove the entire center console first for access.!! A pain but doable. Also remove hrs air vent(4 screws).Then you have to remove the 10 wires from the switch from side of mode switch. Make a diagram where they go. Then remove the 2 blackvacuum lines from vacuum switch attached to side of mode switch.
Then remove screws holding the switch in place from the front and maneuver the switch out of radio opening.
May have missed something but did mine 6 months ago and memory fades. All can be done in a day but I took 2.
My switch had one bad microswitch out of the four. The microswitch which the green wire attaches to was bad and not sending power to the remaining microswiitches . This microswitch sends power to the remaining 3 microswitches. This one must work or the system is dead.
Tonytonem (05-23-2021)
If you need a test switch to substitute, I can send you the one pictured. New ones are well over $300 if you can find them. I bought the last NOS one still in the box in the country I think to keep as a backup if needed and was expensive. David Boger probably has a good one, but test anyone you get before putting all the stuff back together. Just hook up all 10 wires to switch and leave it outside the panel.
eurotire (09-16-2015)
they just fell off, tightened all connections and retested during each step of reassembly. The pictures Saemetric sent were just what we needed though. while trying to remove the switch we removed the two screws which hold the bracket for the defroster vacuum switch, we couldn't figure how to attach it because the bracket fell into the wires below. Thank you again without the picture we never would have figured it out.
rusty37
04-05-2020 07:40 PM
Bhoyceltic
US Southwest
09-03-2015 09:11 AM
FS[Western US]: XJS Wiper Motor Upgrade- 76-88 - Electrolux Style
XJsc-guy
09-02-2015 11:43 AM
