85 XJ6 sunroof stack
If you have the little hand crank, try that.
If not, remove the rear seat and you'll see the cable drive mechanism. By removing a couple bolts ....they'll be obvious....you can remove the drive from the motor and slide the sunroof closed. Unless, of course, it is jammed on its tracks.
Mkii250 (05-12-2021)
