86 XJ6 dash removal
I just received a factory wood trim kit for my 86 XJ6 vdp and would like to make preparations to install it. I believe I need to remove the dash in order to complete a proper installation.
Can anyone tell me the procedure for removing the dash? What other parts should I consider replacing or maintaining while the dash is out?
Also, the wood on the shifter panel is totally shot. That was not included in the kit. Anyone know where I can get a replacement, or get mine refurbished?
Best regards!
Jay Hieb
Best regards!
Jay Hieb
Received 10,871 Likes
It's been a few years but this will cover the high points.
-remove under-dash panels and loosen steering column nuts. No need to remove them. You just want the column to drop 1/2" or so. Remove glove box door and glove box liner
-remove upper pad by removing screws under the lip. The pad then just lifts away. Be mindful of the temp sensor tube just above the glove box door
-remove plastic end caps at the ends of the dash
-remove center a/c duct. It just pulls out.
-remove map light. It just pushes upward and dangles.
-remove srcrews holding dash in place. As I recall there are a couple at each end and several along the top
-tilt dash back a bit and disconnect the two instrument harness connectors. You can leave the gauges in place.
-disconnect air outlets at end of dash
-at this point I think the dash can be lifted away. Be careful...check for anything I may have forgotten. Go slow. Keep track of everything. It's a several hour job.
Reassembly tip: when attaching the metal backing to the new dash make sure to fit and adjust glovebox door at the same time. Actually, it's more like adjusting the *dashboard* to fit properly around the glove box door. When the clearance/fit around the glove box is good tighten down the umpteen tiny screws that hold the metal backing to the wood.
busfreak (12-21-2011)
Doug, I'm really grateful for all your assistance. You have been so helpful.
From what I've heard, the dash can be a bear. So I want to go into this Dash renovation armed with a some upfront knowledge. I don't think I would want to take this on just following my nose. I appreciate the instructions and tips!
Best regards!
Jay Hieb
Best regards!
Jay Hieb
rusty37
04-05-2020 07:40 PM
jagent
09-12-2015 01:40 AM
Chet Ramnarain (bozzner)
09-03-2015 12:21 PM
