86 XJ6 Power Steering Pump
I have a 86 Xj6 VDP, the problem is the powersteering pump. It seems is if it is starting to fail. The belt is and has been tightened and that did not fix the problem. The belt squeeks when th car is cold when the slightest turn is applied. When it warms up i can feel the pump slightly working and when i put to much pressure at on time aka ( turning a corner) it will squeek. I checked the belt its ok, the Pump is filled to the proper level. Could it be the pump it self? if so is there a way to check it and what am i looking for to find out if its bad.
Kamak
Kamak
that's a GM Saginaw pump, just go to any salvage yard and pull one from any GM car.
about $20. at Pull-A-Part.
Or, go to any auto parts with yours and match it with a rebuilt pump. The only difference you might encounter might be the mounting bolt threads might be SAE instead of Metric, in that case just buy new bolts for about $1.00.
Same for the Air Pump. (Delco). Same for the A/C Compressor, (A6 Harrison). Same for the Ignition Amplifier. (Delco).
Jose
Jose
Kamak,
Do yourself a favor and replace the belt with a Jaguar factory belt. The power steering pumps almost never fail, and it would have to be intermittantly binding up to make the belt squeal.
Harry's House of Belts might have supplied something that is on your car now, and is not the correct width.
Received 10,872 Likes
Jose
Jose
I hate to pick nits, Jose, but your advice, which is basically sound, is a little too broad !
GM hasn't used the old Saginaw pump in ages so you really can't get one from "any" GM car.
Same with the A6 compressor.....with fundamentally unchanged for 20-some years, there are actually several sub variations and they are not all directly interchangable. You can't just grab any old A6 as you might grab the wrong one !
I hate to pick nits, Jose, but your advice, which is basically sound, is a little too broad ! GM hasn't used the old Saginaw pump in ages so you really can't get one from "any" GM car. Same with the A6 compressor.....with fundamentally unchanged for 20-some years, there are actually several sub variations and they are not all directly interchangable. You can't just grab any old A6 as you might grab the wrong one !
Cheers DD
Cheers DD
that's why I said "go to any auto parts with yours and match it".
But not before saying.....
"that's a GM Saginaw pump, just go to any salvage yard and pull one from any GM car.
about $20. at Pull-A-Part."
......which could very easily having an inexperienced person doing exactly what you advise them to do and then coming home with the wrong pump. Which could also happen if they took you at your word about the A6 compressors.
And while were on the subject of giving correct information, the amplifier is made by Lucas. The module *inside* the amplifier is GM/AC Delco. If you send someone to a GM/Delco source for the *amplifier* they will end up wasting a lot of time and coming home empty handed.
are you absolutely sure it is the Power Steering Belt that is squealing?
Have you checked the Alternator Belt for tightness too? To get to that one, you need to remove the Splash Panel under the radiator, and then you see the Alternator Belt adjuster. Try adjusting (if needed) the Alternator Belt.
Also, the Air Pump itself is a known squealer when they are starting to go. That belt adjuster you can access from the top.
Jose
Jose
rusty37
04-05-2020 07:40 PM
Dicque
09-19-2015 12:53 PM
