87 Dash Pads
Can't say if they are available new, but I've had pretty good luck at Pick n Pull junk- er, I mean recycling yards. I know there are are several in California so there may be one not too far from your. These dashes (aka "crash rolls" in Jag-speak) don't usually split as they age, so the quality of a used one should be fine.
If you want new, one good source you may be familiar with is SNG Barratt. They seem to have nearly everything. I think they are a forum sponsor as well.
Good luck,
Andrew.
Good luck,
Andrew.
larney (08-20-2015)
Received 10,873 Likes
I'm fairly certain it is NLA---no longer available--from Jaguar.
An alternative, if a good used one doesn't pan out, is a 'cap'
American Dash Caps Jaguar Dash Caps
I've had good luck with those on other cars.
larney (08-20-2015)
Received 2,399 Likes
Or:
1. David Boger aka everydayxj for a good used pad.
2. Can't come up with the name. but, a facility ion Van Nuys CA rejuvenates pads from many cars. They did a nice job for my son's 64 Chrysler 300K. Two tries, but cheerfully redid it much better.
3. The local auto upholstery shop just might. I've seen a pair of visors redone in tht fashion. Better than original and the visrs are similarly configured as tot he crash roll/dash pad.
4. Just get a rug made to cover it. My cars have them to protect the underlying vinyl. Look better to me!!!
Carl
Carl
davidboger (08-21-2015)
here's one, the picture seems correct.
1972-87 Jaguar XJ XJ12 XJ6 Molded Dash Pad Cover - 1AIDC00256 at 1A Auto.com
