87 xj12 fuel tank sending unit
here2for (08-09-2017)
yes, at the back of each tank behind each tail lamp.
first precaution: disconnect the BATTERy, you don't want electricity while doing this, then disconnect the two wires at each sender;
you need to use a Brass punch or something that does not produce a spark as you back it out counterclockwise hitting the punch with a wood mallet, it can cause an explosion to use steel.
also open the filler cap as you are removing them.
