87 xj6 -- how to remove center console?
Received 10,871 Likes
If you just want to remove the wood grain panel around the gearshift it isn't too hard.
It's been a while so what follows might not be exact right down to the last letter but it should get you in the right direction...
remove ash tray inserts
remove ash try housings----two screws each
remove cubby box liner---several screws visible with lid open
remove connectors from the back of the switches
remove single screw at the very top of the "ski slope" just above the switches
remove rubber seal at base of the gearshift housing
remove wood grain panel
The sloped part with the switches is bolted to the wood grain panel....you'll see. The wood veneer can be scraped off and replaced with black vinyl. Looks very attractive, actually.
Oh, the ashtray housings are fussy to reinstall (you'll see). Longer screws help.
And to take the cubby box out you'll also have to pry out the friction latch. If you break it it, you won't be the first
Shout back if more help needed
The main dashboard is a plywood piece about 5/8" thick with a veneer. It has a metal backing plate screwed on
So now the car won't start all of a sudden, did I mess up something during my console removal and install? I thought it was the battery since I bought it last week and the car was not driven often before. Did the starter crap out coincidentally? All electrical functions are good, just won't crank.
I have an 85 XJ6 Series lll Vanden Plas. My shift console is black leatherette and I would like to change the two level wood panel below the tray hood and above the radio and comsole to black leatherette.
How do you remove/replace the radio and trip computer panel?
It's been a few years so a couple details are a little foggy, but this should get you in the right direction:
- Remove trip computer. It pulls straight out. Just get your fingernails under the edges. Disconnect wiring plug
- Remove climate control knobs.
- Remove the shaft nuts behind the climate control knobs.
- You *might* have to remove the radio....but maybe not.
- Look upwards from below the panel. You should see two screws above the radio. Remove them
- Gently pull the bottom of the panel towards you and away, then slightly downward. The top of the panel has tabs that should disengage
- Remove wiring from switches, cigar lighter, etc
the Factory Service Manual provides the steps needed to remove 95% of anything you want to remove.
you can go to XJ-6 - XJ-12 'HOW TO' quick links (always located at the top of the topic list), and download the .pdf file for any section of the car you need, or you can download all the sections. Free.
the Service Manual files are located near the end of the list of How To's.
rusty37
04-05-2020 07:40 PM
Chet Ramnarain (bozzner)
09-03-2015 12:21 PM
MC36
US Lower Atlantic
09-01-2015 07:34 PM
