'87 XJ6 SIII - Overheating
Old 10-11-2012, 12:21 AM
Doug's Avatar
Received 10,988 Likes on 7,215 Posts
Originally Posted by tycarpenter
I will also remove the radiator and have it cleaned as advised. I just wanted to avoid removing the fan, etc. to get the radiator out, then reassemble and find out I had a bad water pump and have to remove it again.
Can't fault that logic :-)
Old 10-11-2012, 01:53 AM
tycarpenter's Avatar
Default Problem solved!!!
Well, I got to work and pulled the fan and shroud, then removed the radiator to have it cleaned.
Then I proceeded to the water pump by removing the belts and hoses. While removing the bypass hose, I noticed a string dangling out of the water pump inlet. I pulled on it and out comes a shop rag. It turns out Doug was right (again).
Originally Posted by Doug
Then I'd say you have a major blockage in flow to or from the pump
The fire in the car was during the test drive stages after an engine swap my father-in-law did. Apparently he forgot to remove the rag protecting the inlet before installing the hoses, oops. I have to give him some credit since the engine swap was a pretty major feat for a DIY job.
Now I need to hook up my garden hose to make sure that the rag did not damage the pump.
I will let you all know how she runs after I get the radiator cleaned and put it all back together.
Old 10-11-2012, 07:21 AM
Doug's Avatar
Well, I'll be damned! Overheating solved by shop rag removal. That's one you don't hear every day ! :-)
Old 10-11-2012, 09:19 AM
ronin's Avatar
On the one hand, great that you found the problem. Hope it didn't damage too much of anything else.
Since you have the radiator out, I'd still recommend getting it rodded and throughly cleaned. Pretty much guarenteed it is some % full of crapola. You should then have no more cooling issues for a long while.
Eric
Old 10-11-2012, 10:17 AM
Jose's Avatar
Received 2,482 Likes on 1,865 Posts
Well, I'll be damned! Overheating solved by shop rag removal. That's one you don't hear every day ! :-) Cheers DD
well Doug, you got caught red-handed! you need to remember to remove rags from Series 3 XJ.
Old 10-15-2012, 09:11 PM
Default Final Update
I got the radiator back from the shop today, and I couldn't wait to get the car back together. I went for a drive and it is staying right around 90 C. It is only about 66 F and windy, so I will not be able to truly test it until we get a warmer day (if we even get another one this fall), but the cooling system seems up to par.
Thanks again for all the input and help!
Old 10-15-2012, 10:33 PM
Doug's Avatar
One time, years ago, I was replacing a head gasket on a Ser III. Common practice to keep bolts from dropping into the engine is to put some rags in the open area where the timing chains fit up into the cylinder head.
Double checking the cam timing means turning the engine over by hand.
Do you see what's coming?
I spent hours picking out shards of red shop rags out of the timing chain!
vwbusbits
10-13-2015 03:43 AM
bydand
09-28-2015 09:47 AM
bydand
09-27-2015 12:00 PM
42Ajd
09-26-2015 07:04 PM
Woznaldo
09-26-2015 11:02 AM
Quick Reply: '87 XJ6 SIII - Overheating
