87 XJ6 VDP Heater
87 XJ6 VDP Heater
Ok here is where I am with my heater issues....
Replaced and relocated the heater valve and it is working properly.
Replaced the thermostat with a 190 deg model and my Jag finally gets up to operating temp.
Both fans are working and change speeds at low and high settings
Outside temps have been anywhere from the teens to 41 today over the last few weeks.
With the temp on 75 and the fan on high I get a nice warm air from the vents on the center console and the rear vent. The upper vents are cool to cold. The bottom vents on the blower cage are both closed and she's pulling air in from the cowl vent like crazy.
Any thoughts?
Any thoughts?
*Correction - As long as there is power to the solenoid there will be vacuum to the blue hose and the blower vents will remain in the "Fresh Air" mode.
With the engine at operating temp and the heat off the vents remain in the "recirculation" mode with the bottom flaps open. When the heat is turned on they close and the system is in "Fresh Air" mode pulling air in from the cowl vent. My understanding is that at Max Heat or Max Cool the system would go into "recirculation" mode. With temps in the low 20s at times I'd expect it to be in Max Heat mode. I'm wondering if I have a bad temp sensor.
My next thought is to wire an ingnition powered switch to the solenoid to give me control of the air source.
Any thoughts?
Any thoughts?
My bet is on the A/C Amp....
Sometimes I send several hours testing these things, and it's amazing the difference you get from one to the other.
One amp will give all A/C... Some are stuck on heat only.... Some change the air coming from the vents (locations), and then occassionly one will do it all correctly...
If you want to test what I'm talking about... I have a couple that are stuck on heat only, that I've been debating on whether to throw out or not.
I'll be glad to send you one, free of charge, just to see if it has an effect on the way your system operates....
David Boger
www.EverydayXJ.com
David Boger
www.EverydayXJ.com
Any thoughts?
Any thoughts?
The recirc door operation you describe seems to be correct as well. They only open to the interior for max heating and cooling, most of the time they are closed.
Good luck.
Doug (02-07-2011)
Received 10,988 Likes
I understand. What I'm saying is that the thumbwheel adjustment isn't likely your problem....as it's only capable of changing the bias by a few degrees.
I'd go with the flap adjustment procedure as outlined above.
aholbro1
08-05-2021 05:02 AM
rusty37
04-05-2020 07:40 PM
