88 XJ6 RH brake/turn light not working
1988 XJ6 Vanden Plas. RH rear brake light/turn signal stopped working along with upper brake light. Tester shows current coming in from wiring harness to the light bulb circuit board. All fuses up front are good. Checked all bulbs. Interestingly the running light works.
The light bulb circuit board is good, as I tested it on the working LH side. I disconnected and cleaned all of the sockets leading to the turn signal box in RH trunk. Still getting Circuit 1, Circuit 2 and bulb failure error messages.
Is this a relay problem? Not sure where to look next...
sounds like you have a USA XJ-40 (Series 4 XJ-6) . This forum is for the Series 1, 2, and 3 XJ-6 from 1968 to 1987 in the USA. (from 1968 to 1992 in Europe, Canada, and Australia). Very confusing.
you might ask the question in the XJ-40 forum.
Tony K
03-26-2024 01:53 PM
FS[SouthEast]: GenRad GDS-510 scan tool
johnnie ryall
10-19-2015 09:44 PM
SingBlueSilver
08-27-2015 02:20 PM
